How to make an opening in the floor?
Select "Create Room-Structure-Floor Opening" in the left list and drag it into the scene to make a hole in the floor. After the hole has been opened, you can adjust the size and position of the opening in the 2D plane view by dragging directly, or adjusting the size value in the right property panel.楼板开洞.gif
6660 16
Comments(16)
Juyeon Cisauk 26 July 2023
yeaah me too, no floor opening. @ lisabecka
There is no floor opening option in my Homestyler. Next to Cylinder there's just Sunken Ground and so on.
Tania Bertholdi 27 January 2023
My room is odd shaped - not square, so cannot open a hole using the Floor opening tool. Please help.
Vidir Geirsson 29 July 2023
So you need to go to edit floor and then you click the option rectangular floor opening @ lisabecka
Mariya Klimchenkova 27 July 2023
How to make an opening in the floor in V 5.0?
John Dada 23 August 2023
Found it in V5 under Model Library / Structure / Wall opening / Ground Opening @ Juyeon Cisauk
why dont i have floor opening in the version?
helenagomesaraujo98 9 September 2023
Não me aparece essa opção de "FLOOR OPENING"
Found it in V5 under Model Library / Structure / Wall opening / Ground Opening @ lisabecka
Found it in V5 under Model Library / Structure / Wall opening / Ground Opening @ Mariya Klimchenkova
John Dada 22 August 2023
can't open the design you started in V5 into the V4... @ Gina Manolea
go back in V4
Gina Manolea 27 July 2023
go back in V4 @ Juyeon Cisauk
go back to V4 @ Tania Bertholdi
you need to work in V4 for this option @ Juyeon Cisauk
lisabecka 19 July 2023
Rey L 5 May 2023
Is there a way to lock the openings? Mine keep moving to the 1st floor every time I reopen it.
