How to adjust the room size and wall position?
Left-click to select the wall in 2D plane view, and you can drag to modify the dimension to make adjustments to the wall's position. You can also directly type in a distance value to adjust the room size and wall position.调整房间尺寸.gif
0 2831 6
Comments(6)
Aleksandra B 8 July 2022
I cannot edit the length - can only modify height and thickness. Can you advise?
8 Reply
otdmunka 22 May 2022
For me these numbers are not showing up :(
3 Reply
peacefulguy forhonor 7 June 2022
what to do if i dont have sizes near the walls?
2 Reply
Reem 23 August 2022
Change the floor plan to plane 1, then you can move the walls@ Nidra Zabci
hi ! Did you get a response for your inquiry? I can’t see the answers! I have the same problem. I can’t change the length (width) of the wall, I have exact measuremnts but I cant seem to enter them on my floorplan. Let meknow if you got an answer! thank you!
1 Reply
Nidra Zabci 5 August 2022
hi ! Did you get a response for your inquiry? I can’t see the answers! I have the same problem. I can’t change the length (width) of the wall, I have exact measuremnts but I cant seem to enter them on my floorplan. Let meknow if you got an answer! thank you!@ Aleksandra B
1 Reply
Hacı Bekir ALTUNTEL 10 September 2022
Hi this feature is not working right now Can you check it?
