Update more pocket styles,and more
Floor Planner 09/2021 Release Notes - 【General Features】 related updates
1.Update more pocket styles
2.Wall drawing tool supported wall angle setting
3.2D and 3D view added furniture positioning line, RCP added lighting positioning line
4.Restrictions on the size of "Floor Opening" and "Sunken Ground" are reduced
5.The baseboard can be applied to all rooms with one click
6."Replace Material" supports restore to the original material
7.Added "Sign Out" function in the design interface
8.New designs added the automatic save function
3139 0
