Supported Batch Watermark Removal,and more
Floor Planner 09/2021 Release Notes - 【Render】 related updates
1.【Member Exclusive】Supported Batch Watermark Removal
2.【Member Exclusive】Render editor supports "depth of field effect"
3.Normal pictures added Auxilary lines
4.Added 15 kinds of "Spot Light"
5.Added opening animation to panorama
0 3140 0
