How to sink garden level and place plants on it?
Sophie 24 July
Hi, I'm trying to finish the garden for my cottage, but i can't figure out how to sink it. I could sink the stairs by inderior modelling playing around with "extrude", but when I try to place plants on the stairs, they're floating, as it's under 0 level. (The first floor is set to 0 level originally).
I also want to sink the soil around the house, as the porch is elevated (that I made with "extrude" downward). But the plants on it will also be floating in the air. There's no option to sink objects, only elevate. (e.g Elevation: -2,0) I can only give positive numbers in the elevation field.
I'd like to model something like these:
I don't want to elevate the whole house though on a higher level just because of that, as than I should count every single structure again, and it would be difficult to measure it too, and the house plan is more important than the garden.
Any suggestion, please? Thank you
323 2
Comments(2)
Sophie 25 July
Thanks. A bit time consuming, but it works. Thank you!
Homestyler support 25 July
Hello, you can press 'Ctrl' on your keyboard while you dragging down the plants:)
