Adjust height of Outside Area
Roman - 6 January
Hello, I have basement and "top" floor. I want to add Outside Area but by default its added too high - i need to adjust the height (Z axis) of the area. How to do that, please?
279 1
Comments(1)
Homestyler support 7 January
Hello, we kindly remind you that the outside area can only be added to the ground floor:) And currently there is no proper method to adjust the height, but we suggest you can draw another room then hide the walls, unshow the ceiling, replace the texture of the floor instead of creating the outside area. And you can also draw the floor manually in 'Interior Modeling' to the place you want:)
