Hello! How can i upload a profile (molding)? Zip file is not visible when i try to upload. If i extract, i see only .dwg and .dxf but doesn't work. Thank you
In the end, I used a 3D model, because the “Profile” option doesn’t accept the files I uploaded (.max..etc), only this are visible and in the end doesn't work (.dwg, .dxf). However, adding the molding as a 3D object takes much more time than it would if I could upload it as a profile with profile properties that can be applied automatically.
Please add more classic cornice and molding models — they are very much missing.
