how to adapt the size of my floorplan?
k.gerheuser 1 November
Hello!
I´ve just finished building the walls upon my floorplanas I did before to realise now that the flat on my plan is way to small. Can you tell me where I went wrong or how I can still change what I did (scaling, maybe)?
homestyler shows me as total size of the building 25:78 m² (so I struggled with doors and windows, haha)
but real size was 130 m²
thank you!
192 4
Comments(4)
Homestyler support 4 November
Hello, when generating floor plans, there may be some deviations. You can manually adjust the dimensions afterwards, or try importing floor plans in 'dwg' format.
Majerina High 3 November
It is better to indicate with a ruler the known size of the wall - even approximately - if you know that the door is 900 mm, and the partition is 500, indicate this with a ruler, then the plan will be generated more or less adequately
The site has a joke - if you import a plan in jpg format or any image and set the dimensions of the apartment area, then forget about the scale) the site applies your area to the entire area of ​​the image, so you need the area of ​​the entire image, and not the configuration of the apartment
Arianna B 1 November
hi, I think that the right measurement (m, cm, mm) must be set at the beginning when importing the plan or right before. I don't now if now you can scale what you've done, sorry.
