GLITCHES
Grace Simmons 2 May
Everyday I sign on and work on my contest design, I find more and more glitches. Now I have a lighting problem with a multi floor design. The ceiling and walls are the same color but render as two differnt colors. The lighting plan--no matterwhich one I use, including an editied one darken my ceilings. Two rooms withte same colored walls and ceilings render completely differently. Contacted support but seriously doubt they will fix or provide a solution in time for the design to be entered into the contect. Been a constant user for over 3 years and am delighted with each improvement, but keep finding more glitches that are hardier to create a work around for.
0 188 2
Comments(2)
Homestyler support 6 May
We also suggest you add more lights or adjust the environment brightness to improve the render effect.
Hello, We suggest you to check if you have changed your lighting setting?
