Help needed
haaksluototaika 17 November
How can I lower the floor of one room in the second floor(upstairs)? The floor upstairs is set to the same height in every room and I want one of them to be lower than the others. Even if I make the walls shorter in the lower room the upper room's floor is still at the same height. pls help
85 3
Comments(3)
Grace Simmons 19 November
Custom floor/custom modeling are interfaces. Custom Floor: https://www.homestyler.com/forum/view/1486282622105964545?spm=a1zmxy.26381983.0.0.39284cb4Qml7T3 OR https://www.homestyler.com/learn/full-house-furnishing Interior (Custom) modeling: https://www.homestyler.com/learn/interior-modeling @ haaksluototaika
I believe I have custom floor but I can't change the measuraments of it
Grace Simmons 17 November
The only way to create the design you want is to use custom floor or custom model to raise up rooms that need to be higher.
haaksluototaika 19 November
I believe I have custom floor but I can't change the measuraments of it @ Grace Simmons
