issue with electrical installation
kontakt 7 Janeiro
Hi,
The issue with the program is that when I generate an electrical installation on the second floor and try to set up lighting controls, two problems occur. Firstly, the dashed lines connecting the light switches to the lamps are not visible on the second floor. Secondly, all these lines appear on the ground floor instead of being distributed across the correct floors. The same issue occurs when exporting the drawing to a PDF. All the lighting control elements from both floors are combined and shown on each floor, making the drawings unclear.
How can I / You sove this?
361 3
Comentários(3)
Homestyler membership
Homestyler support 9 Janeiro
Sure, thank you for your feedback, it will be well considered and fixed:) @ kontakt
There’s also another issue with the electrical setup. For example, when adding light points on the terrace, outside the building, I created outdoor areas but couldn’t select those elements to add them to any electrical circuit. My workaround was to temporarily move them to an indoor room within the building and only then arrange them outside. This is another issue worth addressing.
Responder
kontakt 8 Janeiro
Responder
Homestyler support 8 Janeiro
Hello, we received your report, and we are going to fix this issue, we will feedback asap:)
Responder
🎉 Tarefa concluída! Você ganhou moedas!
